08-06-2024, 04:41 PM
mike919 mike919 is offline
Hello, I need a video editor to process my processed VHS footage without loosing details/quality
I’ve tried
OpenShot - Outputted a compressed mess
DaVinci Resolve - Sort-of worked? It made it 16:9 and not 60fps in the output. (Anyone recommend settings?)
AviSynth - Works for trimming clips, I don’t know enough to compile clips together though
If anyone knows any recommendations - throw ‘em at me
mike
08-07-2024, 09:26 AM
traal traal is offline
To use AviSynth to join clips:
c1 = AviSource("clip1.avi")
c2 = AviSource("clip2.avi")
c1 ++ c2
The AviSource commands above can also take .avs scripts if you prefer.
08-07-2024, 02:07 PM
VideoReDo TVSuite could do it losslessly, but unfortunately its creator passed away and the company is defunct. Someone set up an activation server for existing users, but nobody can buy a new copy of it anymore.
08-07-2024, 02:17 PM
Thanks for the the recommendations, I can compile them now
mike
#editing #vhs
TBC before/after clips? rabbitfeet318 Capture, Record, Transfer 16 04-07-2024 09:25 AM
Which of these clips is a better capture? RandomMixTape Capture, Record, Transfer 2 12-15-2021 06:00 AM
VC500 clips superblacks, but not in XP? bilbofett Capture, Record, Transfer 3 04-05-2017 03:57 PM
Archiving movie clips off my still camera Sossity Project Planning, Workflows 4 11-04-2007 07:36 PM
Merging clips and removing commercials mlaviolette Encode, Convert for discs 5 11-12-2004 05:11 PM
