10-27-2018, 10:19 PM
rocko's Avatar
rocko rocko is offline
My "Video Editing" win 7 PC crashed, which I used VirtualDub to mainly just cut down large captured .AVI files into 6 minutes or less chunks, and it had the Huffyuv codec installed. And these .AVI files were created on my Win XP "Capture" PC, with Huffyuv codec installed.
Now I am starting from scratch again with a different win7 PC, installed current version of VirtualDub, and question is, do I need to install Huffyuv in order to successfully view and edit those captured .AVI files, using VirtualDub, they play just fine using VLC player.
I had all this stuff memorized about 5 years ago, and everything was "automatic" once it all was working fine, untill the PC crashed. Now my old brain forgot a few things!
10-28-2018, 05:05 AM
Yes.
32-bit huffyuv v2.1.1 download -> https://www.videohelp.com/download/huffyuv-2.1.1.zip
You won't need 64-bit hufffyuv. 32-bit works just fine in 32-bit and 64-bit systems.
See Installing 32-bit codecs in 64-b it Windows.
The following users thank sanlyn for this useful post: lordsmurf (10-29-2018)
Cannot install HuffYUV on Windows 64-bit Vista/7/10/11? [SOLVED] phyxius Encode, Convert for discs 41 06-20-2024 03:40 AM
Cannot install HuffYUV Multithreaded in Windows 8 64bit kaliree Edit Video, Audio 3 03-17-2014 01:59 PM
Can I edit .mov files on PC to burn on DVD? kcmom Encode, Convert for discs 1 07-30-2012 08:30 AM
How to edit/convert DVR-MS files with Premiere Elements ? Kelly Edit Video, Audio 21 11-11-2007 01:30 AM
How to edit IFO/ISO/VOB files? mlaviolette Encode, Convert for discs 2 02-12-2005 08:25 AM
