06-10-2025, 03:15 PM
Originally Posted by Thermaltake View Post
Hi, I was planning to buy AVT-8710, but I saw that it is US device which works on 120V input. I am from EU we have 220V input power here, any suggestion for some equivalent TBC like that one with EU current ?
You need a 12V- power supply. Those can be 100V-240V, and come in all shapes of plugs. (The 15V- can be iffy if amps too high.)
Can You tell us what brand of adapter you offer and give some picture if that's not such a big secret.
PSU brand can vary on factors. What I have now is a specific APD. Outcome is 12V- power with a power switch, exactly what this specific TBC needs and wants..
It's not a "secret" but rather the fact that that photos show/prove nothing. It's completely about the performance, non-visual aspects.
If you want to see random photo of what an APD power supply looks like, use Google Image search.
The caveats of AVT-8710 TBC PSUs is something I only know from years of experience, and it's not easy to teach. Just trying to teach it would take a verbose novel, which is not something I have time to write. Even EEs don't know all the gotchas of this exact TBC (been there, done that).
Originally Posted by Gary34 View Post
The offering of the right power supply like that is him trying to preserve gear. He’s only charging 22 dollars. I doubt he’s making much off of chargers. It’s not like he’s marking them way up like Tgrant does.
$22 for the PSU is literally costs rounded up. Maybe some coins in profit, whoop-de-doo.
EDIT: Actually, it's not even costs individually. Some of these items require buying in 5-packs, so my $22 cost is actually item/5, cheaper than one-off buying (but noting that one item in the kit is only sold in 2-packs or 5-packs).
I don't play the "I nEeD pIcTuRes!" game. I'm not some Facebook/etc random nobody. That's always a person trying to pump me for information, no intention of buying my gear (even when it's for costs, FFS!), not understanding (sometimes stubbornly) that (again!) images/photos prove nothing.
If anybody want to find a PSU themselves, then nothing more I can do for them.
Certain TBCs are temperamental. The wrong PSU = failed TBC, sometimes irreparable. The AVT-8710 have the added bonus of not having a power switch, and the dangers that entails, thus needing to be addressed.
For some people, "finding my own" works out, often because of dumb luck.
For others, it's FAFO.
Originally Posted by ge0dude View Post
complex electronic device.
I think, in another thread, you mentioned being an "audio guy". For this TBC, if all the parts are correct, polarity reversal cables are your friend. (If the wrong parts, keep a fire extinguisher nearby.)
The following users thank lordsmurf for this useful post: ge0dude (06-10-2025)
06-10-2025, 11:50 PM
Thermaltake Thermaltake is offline
I have some input 100-240V output 12V 800 or 1000mAh adapters I'll just reverse polarity inside adapter and install inline power switch.
But I am wondering why did they put default 15V 600mAh then if it can be iffy ?
06-10-2025, 11:54 PM
Read my statement again. You answered your own question.
06-10-2025, 11:58 PM
Ok if amp is too high, but what if it's a bit more like 800 or original 600, that would be ok ?
Or you still rather recommend 12V with more amps instead of 15V whatever amp ?
06-11-2025, 12:19 AM
Gary34 Gary34 is offline
You could just try it and see how it goes.
06-11-2025, 12:56 AM
I have no problem in testing it when it arrives but until it does he said he did all kind of tests with that tbc, so I assume he test that too. So he can enlighten us for some knowledge.
06-11-2025, 01:35 AM
I still think the best bet would be to just buy the PSU from LS. It’s your choice though. Hopefully it goes well for you.
06-11-2025, 01:52 AM
But I have a lot of 12V adapters at home... doesn't make sense to buy it from him. I just don't have one with 60Hz all EU are 50Hz, don't know if that will make any problem.
Just need reverse polarity and install inline power switch. But it won't hurt to know if he test it with 15V to know the stuff I asked.
06-11-2025, 02:12 AM
But why would I buy something I have at home... doesn't make sense at all. Just need reverse polarity and install inline power switch. But it won't hurt to know if he test it before to know the stuff.
I’m using an OEM PSU and they are known to fail. If mine fails tomorrow then I am going to LS because to me it’s not worth the risk to save that little and potentially mess up an item that is worth as much as a recommended TBC. Then if I have to trouble shoot I know that it is an unknown variable. 20 bucks just isn’t worth the time I would spend thinking is this the issue? That’s just my point of view on it.
Maybe you know more about all of that though and it will work out. Good luck.
06-11-2025, 02:22 AM
It won't be my first adapter to service or reverse polarity or install power switch on it. I was just eager to know his experience with all that voltages and amps.
06-11-2025, 11:44 AM
ge0dude ge0dude is offline
If the shipping cost is a little out of reach for you right now, I would just wait until you have the money saved up. The last thing I would wanna do is ruin a rare recommended TBC.
Just for your edification, according to easyship.com, a 0.5lb package from California to Croatia would cost about $20 with tracking. And I'm sure it's less than 0.5lb. so you'll probably be in it for $40 tops.
06-11-2025, 12:45 PM
I'll see when unit arrives. I still don't have it. I will probably get adapter from LS if he will have one then, but need to get unit first.
Correct power plug for Elite BVP4+? BarryTheCrab Video Hardware Repair 16 05-01-2022 07:57 AM
Why plug the VCR and wait before turning on? mbassiouny Project Planning, Workflows 5 12-07-2021 07:17 AM
What Euro plug do I need for green AVT-8710? Patrick_S Capture, Record, Transfer 9 01-01-2021 12:42 PM
Re-thinking my current capture cables and power set-up! rocko Project Planning, Workflows 14 07-23-2015 06:25 PM
Photoshop Plug In battle7 Author, Make Menus, Slideshows, Burn 1 10-22-2006 05:57 AM
