06-10-2025, 05:16 AM
Hi, I was planning to buy AVT-8710, but I saw that it is US device which works on 120V input. I am from EU we have 220V input power here, any suggestion for some equivalent TBC like that one with EU current ?
06-10-2025, 06:16 AM
You can find step down adapters for under $10 on your favorite online shopping site. The AVT-8710 works with NTSC, PAL, and SECAM.
06-10-2025, 06:23 AM
But I would need 220V to 120V step down adapter, and in my local store I only find 220V to 110V. Because as I saw original AVT-8710 adapter have 120V input.
06-10-2025, 06:30 AM
110V is within spec. No worries. AC power is more of a range than a set voltage. When people want consistent power, they use power conditioners, which usually output a steady 117V. Go for it!
06-10-2025, 07:30 AM
It's rarely an issue but I don't want to say 100% non-issue because the avt-8710 is a more complex electronic device. Maybe someone has a better answer than my "probably not an issue but it's a possibility." -It is an expensive piece of kit there.
Reason: added info
06-10-2025, 07:32 AM
I found on aliexpress converter that have written 50/60Hz on it, so If I get that one It will be ok.
06-10-2025, 07:39 AM
I think this one would be enough if I want to buy it from chipoteka, but on aliexpress is cheaper. 300w is way to much for something that don't even draw 20W
https://www.chipoteka.hr/adapter-220...105-8061400851
06-10-2025, 07:42 AM
That one doesn't say anything about outputting 60Hz, probably a non-issue, but if you're spending so much money on the TBC, you should probably be on the safe side. If it were a simple circuit like a VCR cleaner, I would say go for it. But a TBC is a rare, pricey, deteriorated, and complex piece of equipment.
06-10-2025, 07:43 AM
It's not so much money, I found it very cheap  but of course I don't want to burn it hah plus it will be serviced completely new caps and everything that needs to be replaced. So it will be in better than factory condition.
06-10-2025, 07:46 AM
Regardless of what you paid for it, it's worth quite a bit of money if it's in working condition. Maybe go for the ali option if its cheaper, as long as it outputs the right spec. Although I was disappointed recently by a cheap ali charger. LED lit like it would work, but when i plugged it in it would all shut off, even the LED. haha.
06-10-2025, 08:05 AM
I know, it is worth even more when serviced right. I'll try aliex. didn't have any problem before with any aliex stuff. I order a lot of it
06-10-2025, 10:01 AM
Do not buy a step converter, it adds noise to signals. It's complete unnecessary.
Which exact unit are you using? Is it exactly a green AVT-8710? If so, you don't need any step conversion at all. It's not a "US device" whatsoever.
I can tell you exactly what to get here.
Just confirm exact model and version of TBC.
I'll even get you an EU-compatible PSU for my costs and shipping, and will even test it on my own AVT-8710 (or whatever TBC model it is) before sending out. I've done that many times for others in this forum (for EU, US, UK, Australia, Israel, etc).
Just to be clear, this thing: https://www.chipoteka.hr/adapter-220...0v%20converter
100% useless here. Don't buy that.
ge0dude (06-10-2025)
06-10-2025, 10:07 AM
Green one it is AVT-8710. Don't know exact version didn't get it yet to check that.
I found a lot of adapter with 100-220V input and output 15V 600mAh but I couldn't find anywhere inner - out + pole on connector like original adapter has. I know you can reverse wires inside adapter, but if there is original adapter like that, that would be cool.
06-10-2025, 12:23 PM
At least you stopped and thought about it before just hooking it all up. I would go with what L.S. is saying. https://www.digitalfaq.com/forum/vcr...vt-8710-a.html It’s easier to buy one from him on this and it doesn’t make sense to risk an expensive unit just to save a little bit on an adapter.
06-10-2025, 12:57 PM
Lordsmurf how much is charger with shipping to Croatia ?
06-10-2025, 01:29 PM
At this moment, PSU is $22 USD, plus shipping calculated to an exact address (PM it).
My AVT-8710 power "kit" includes an inline power switch, which you really do want on these AVT-8710s. Just yanking the power cord is never a good idea (and does eventually lead to problems). All my current pieces are new, and the PSU is brand-name (not Chinese knockoff junk that spews noise).
I even have 1 extra on-hand right now, so there's no waiting time to send it, to whoever wants to claim it.
06-10-2025, 01:57 PM
Can You tell us what brand of adapter you offer and give some picture if that's not such a big secret.
06-10-2025, 02:29 PM
The offering of the right power supply like that is him trying to preserve gear. He’s only charging 22 dollars. I doubt he’s making much off of chargers. It’s not like he’s marking them way up like Tgrant does.
One of the things I notice in eBay is when you talk to people they usually have some random charger then not for nothing plugged into there TBC.
