09-17-2018, 03:02 AM
stevevid stevevid is offline
AvsPmod has a feature called Snippets or Text Snippets. You can associate text with a tag. But I don't know what it's for. I took a section of a script and associated a tag name with it. I assumed whenever the tag was typed in my script and I hit return that the text string would show up--it didn't. I searched here and on Doom9. The only thing I found was the brief mention of Snippets being added in the release notes. Any ideas of what it's for?
09-17-2018, 03:06 AM
To me, the bigger question is why you want to use it. What need do you have for it?
09-17-2018, 01:01 PM
My only example at this point:
[Histogram On/Off=1]
Histogram(Select([<"Histogram", 0, 2, 1>] ,"classic", "levels", "color"))
[/Histogram On/Off]
This is a function I believe I will use in all scripts. I thought it would be nice to just enter a tag in the script and the function would show up. There could be other items in the future. I guess I need to create an avsi file instead and put it in the plugins folder.
So, what are text snippets for?
Wow! AvsP/AvsPmod has more stuff than I thought! stevevid Restore, Filter, Improve Quality 1 09-16-2018 12:18 AM
Getting text messages off phones ? Sossity Digital Devices 1 09-20-2011 06:05 AM
Dvd menu text & invisible button manthing Author, Make Menus, Slideshows, Burn 11 06-22-2006 01:21 AM
Remove text from pic, but leave background? manthing Photo Processing, Scanning & Printing 2 03-27-2006 12:47 AM
Adding unlimited text in Adobe Pro 1.5 jrnyhead Encode, Convert for discs 2 05-26-2005 02:05 PM
