Go Back    Forum > Digital Video > Video Project Help > Encode, Convert for streaming
10-07-2023, 01:31 PM
newmy51 newmy51 is offline
Hello DFAQ,
I come to you with a problem that may be a quick one for someone else to solve or diagnose, but which has taken hours and hours out of my life:
https://drive.google.com/file/d/14Za...usp=drive_link
Above is a link to a broken streamrip of an NCAA basketball game, broadcast on ESPN several years ago at https://www.espn.com/watch/player/_/id/3245277 (no longer hosted). The video and audio remain in sync until about the 55:28 mark, when, for a reason I cannot fathom, as another set of commercials begins to play, the video plays at 2x speed while the audio remains unchanged. Thus begins an AV de-syncing that only gets worse as the file progresses, with each commercial break behaving the same, and the audio lagging further and further behind.
When I try to manually resync the lagging audio in VLC, to be able to clip out the portions of the broadcast I need, the video freezes while the audio continues, and the program must be restarted. If allowed to play without messing with any audio delays, the video doesn't freeze, except at the final frame, while it waits for the now thoroughly lagging audio to "finish up." This is true both for the file linked above, and for no less than three separate versions I've run through Handbrake using different combinations of encoding settings.
Continuing to try and fail at fixing this is hurting my brain. I'd be thrilled to end up with anything from one large file to multiple smaller files, so long as all the sync issues are eliminated and the file or files are stable enough to be clipped at the appropriate timestamps. FWIW, VideoRedo crashes instantly upon beginning to navigate through the file, and TS Doctor says "File is encrypted. Process Aborted!" upon opening. MediaInfo located here: https://pastebin.com/B3pYycj3
Any and all help is greatly appreciated.
Cheers,
-newmy51
MiniDV, HDV capturing corrupted tapes? waloshin Capture, Record, Transfer 5 03-12-2023 10:15 PM
VirtualDub to Vegas corrupted AVI files? Denicio Capture, Record, Transfer 4 06-01-2021 01:24 PM
Output file corrupted? (analog video capture) danielscreed Capture, Record, Transfer 2 12-06-2020 11:54 PM
Loilo corrupted video recording after crash! DesignatedGoober Capture, Record, Transfer 1 02-17-2015 07:50 AM
RCA DRC8030N DVD record/player corrupted lordsmurf Videography: Cameras, TVs and Players 1 12-25-2009 04:58 AM
