03-29-2023, 03:46 AM
badonica badonica is offline
Hi,
The more I read the more I get confused.
My JVC decks have Scart/ 4 pin S video outputs
A lot of capture devices have 3 ports
Y Port
B-Y S video - Y
R-Y S video - C
My scart cable has 3 rca tails and I know I can attach the yellow connector to the Y port
But as I’ve read the worst quality transfer.
But as I’ve read -S video is the better way to go-
So can I get a 4 pin S video cable that can connect as described above ?
Sorry if I sound as thick as a badger
Thanks Tom 🍀
03-29-2023, 04:19 AM
Most capture devices have 4 sockets: Composite video (yellow) red and white for Audio, and an S-video socket.
If you have S-video Out on your VCR, that's the best. Get an S-Video cable and use it to connect your VCR to your capture device.
03-29-2023, 06:20 AM
The capture device doesn’t have a S video 4 pin connection it only has the 3 BNC type connectors I described ?
Thanks Tom
03-29-2023, 07:02 AM
Arrh, sorry, I'd lost track of your "capture device".
I recall @Latreche34 showing a pic of a cable that did what you want; he had a TBC that used BNCs. Hopefully he will be along to elaborate.
03-29-2023, 07:12 AM
Hi
Thanks for getting back~ hopefully they will
give some direction to where it was purchased as one supplier told me it wasn’t possible
Thanks Tom
03-29-2023, 07:45 AM
Google: "2-bnc to s-video adapter".
How to add TBC to workflow? zackhammerle General Discussion 3 05-18-2021 04:26 AM
Does this workflow seem like it's going anywhere? CyanUmbreon01 Project Planning, Workflows 5 05-09-2020 02:40 PM
Issue of PC not recognizing Canopus ADVC100. Solution or Alternative? darengibo Capture, Record, Transfer 5 01-06-2019 08:23 AM
VHS capture via ADVC100, edit and compress alternatives? ac427 Capture, Record, Transfer 12 03-31-2018 02:50 AM
PAL vs NTSC, which one to use in my workflow? lordsmurf Project Planning, Workflows 0 03-25-2010 07:39 PM
