03-31-2023, 04:28 AM
badonica badonica is offline
Hi,
Just wondered if someone has a pic of a workflow incorporating the ES10 with respect to connections
my set up would be I think if I got it right?
JVS Player (s video out) to ES10 (would it be s video into ES10) what leads would output from the ES10 to capture device (s video or component?)
03-31-2023, 08:53 AM
Xhumeka Xhumeka is offline
Yes, you have it right. You will need 2 S-Video cables, and 4 RCA/composite cables (Red/White audio).
JVS Player
OUT
S-Video
RCA Left/Mono Audio (white) connector
RCA Right Audio (red) connector
ES10 (assuming using line 1 input on rear, select INPUT on your remote and change to Input 1 (INI1))
INPUT 1 (connect cables from your JVS)
S-Video
OUTPUT (to your capture device - assuming it has S-Video Inputs)
S-Video
If your capture card has only component inputs (red/blue/green) you could connect your ES10 to your capture card using those instead of s-video.
You might also want to look over the recommended ES10 settings posted on this thread: https://forum.videohelp.com/threads/...15-DMR-ES25%29
Any questions/problems just ask! Cheers.
03-31-2023, 10:42 AM
JVS Player
OUT
S-Video
S-Video
S-Video
Thanks for the quick reply - very helpful
Does the ES10 generate a Pr, Y, and Pb on output if the input was by way of s- video connection?
Thanks Tom
03-31-2023, 10:53 AM
I believe so yes, although I have never been able to test since I do not have a component capture card/monitor. Give it a shot, and let us know!
03-31-2023, 10:56 AM
Thanks - “Every days a school day “
Building up the equipment slowly - getting closer
Thanks Tom
03-31-2023, 11:01 AM
The PAL Panasonics do at least (would assume the US models do too but don't have any way to test). The signal is going to go via (digital) component whatever input/output is used. Some later US panasonics (and very late PAL panasonics) only output deinterlaced progressive scan over component as far as I know which you would want to avoid so in those cases S-Video is preferable.
03-31-2023, 12:04 PM
Thanks for the extra clarification
Kind Regards Tom
Will DMR-ES10 benefit my workflow? travvytrain Project Planning, Workflows 1 02-12-2023 07:59 AM
Workflow with DMR-ES10, JVC S-VHS, no TBC? Ninja99 Project Planning, Workflows 1 12-22-2021 09:36 AM
S-VHS VCR with TBC vs. S-VHS VCR without TBC to ES10/15? ShredBraahh Capture, Record, Transfer 1 03-24-2021 03:09 AM
DVK-100 and ES10 workflow setup and configuration? tcirre93 Project Planning, Workflows 1 06-12-2020 10:06 PM
