01-30-2013, 03:55 AM
fortunec00kie fortunec00kie is offline
Hey LS
I know I have not been on the forum in ages!
I have just been busy with outside life for a while.
I had surgery, we moved, switched jobs etc....
Anyways I have a home audio question and I knew you'd be the one who could help me.
I have a Blu-Ray Player that has Optical Audio Output.
The Player is connected to my TV via HDMI.
My TV is a Sony Bravia (Model KDL-40V3000).
I just got a Denon Sound Bar.
My TV Has Optical Audio Output too.
This is what the TV Manual says....
"Dolby Digital Audio from the HDMI input will be Output as PCM"
Does this mean I am better off to connect my soundbar to the Blu-Ray directly, or will the TV pass the audio through?
Thanks for any advice you can provide.
Colin
fortunec00kie
01-30-2013, 04:00 AM
JMP's Avatar
JMP JMP is offline
Former Site Staff | Computers
DTS has a higher dynamic range, than Dolby Digital which is higher than PCM.
The TV will just pass the audio through just fine, but as shown above, PCM doesn't quite have the same dynamic range that Dolby Digital has.
Personally, I would suggest trying both ways and see which sounds best to your ears. It may turn out that it sounds the same to you and doesn't make much of a difference.
-JMP
- Check out my latest Editorial.
Panasonic DMR HS2 DVD Recorder as a pass through for bad quality tapes? Urbane0083 Restore, Filter, Improve Quality 8 09-30-2013 02:58 AM
Parasite sound (audio noise) during capture? monks19 Capture, Record, Transfer 4 05-08-2012 03:54 AM
Audio clean-up options, Sound Forge SSStudio Restore, Filter, Improve Quality 9 12-15-2009 09:10 PM
Sound Card / Digital Audio Cables CaZeek Capture, Record, Transfer 3 12-13-2004 10:58 AM
Help with ATI sound: audio is noticeably lower volume in capture buckcrisp Capture, Record, Transfer 4 05-04-2004 01:47 AM
