12-31-2020, 04:10 PM
Where do I find out if my 2009 Samsung Sh-s223b DVD drive has a firmware update with M-DISC support?
12-31-2020, 04:21 PM
Probably the Samsung site. Search it.
12-31-2020, 04:25 PM
i searched but i didn't find any firmware on the samsung website
My DVD drive is a Samsung SH-S223F / BRDH is there any firmware for this drive that fully supports the M-DISC?
Is there any software to test my dvd drive and optical reader and show if it is bad, reasonable, good or excellent?
01-01-2021, 06:31 AM
SH-S223B
https://www.google.com/search?q=sh-s223b+firmware
https://www.firmwarehq.com/Samsung/SH-S223b/files.html
SH-S223F
https://www.google.com/search?q=sh-s223f+firmware
https://www.firmwarehq.com/Samsung/SH-S223F/files.html
A drive from 2008/2009 won't have anything "new".
01-01-2021, 06:37 AM
The M-DISC was launched in 2009
my drive model is written SH-S223F / BRDH but does the model SH-S223F have a difference in firmware between them?
is this samsung SH-S223F / BRDH model good or bad?
is it possible to correct the defect in the button to eject the drive tray that has fallen and been lost?
what software do i use to write this firmware update file to the drive memory????
samsung drive SH-S223F firmware is the same as SH-S223F / BRDH???
01-06-2021, 08:18 AM
One of my drives will not eject using the button on the drive. But the software command works. So I just eject in the software. It's bad to just shove a drive back in, so I use the load function. If the software doesn't have a load, I'd usually use my other drive (I have multiples per system). But sometimes I need to "no eject" drive (for scanning), so I use DVD Decryper just to open/close the drive, then do what I want, close scanning program, DVD Decrypter again to open/close. Or Imgburn, same thing really.
You use whatever tool it needs. Most are actually using command-line (DOS), but it varies on manufacturer.
01-06-2021, 08:24 AM
what software do i use to update firmware of my drive dvd????
I only have the .exe firmware
question
Best free software to quality scan disc, drive? gamemaniaco Blank Media 4 08-26-2016 06:12 AM
Software for testing DVD drive and DVD disc? samus87 Blank Media 12 12-06-2015 07:12 AM
Playing Blu-Ray on PC with only DVD (or no optical disc drive) kctexan General Discussion 4 09-22-2015 01:24 AM
JVC DRM10 disc error, can't format disc ieee488 Blank Media 5 04-01-2012 09:23 AM
Player can't read disc anymore? BD-R 25GB movie disc error kpmedia Blank Media 0 12-07-2010 11:45 PM
