07-25-2024, 09:21 AM
badonica badonica is offline
Hi,
Captured an AVI with Virtual Dub with Huffyuv codec ( Windows 7 64 bit)
However, when I try to convert in Adobe Media Encoder( AME) - Adobe Production Premiere
only audio is encoded there is no image. Is there a codec issue with AME
When I convert in Main Concept 2 it’s fine ?
Cheers Tom
07-26-2024, 01:58 AM
Adobe hooks into system-wide codec installs only., nothing local (like VLC, some others).
It's not just AME, but anything Adobe.
You need to install the official unpatched Huffyuv 32-bit codec into the 64-bit domain. (No, not the 64-bit codec, which silly enough only installs into the 32-bit domain. Also not the FFMPEG versions.)
MainConcept is the same.
See this post: https://www.digitalfaq.com/forum/vid...html#post94709
I didn't link directly to it, because that thread has similar problems to yours, in case you need to read it.
07-26-2024, 11:04 AM
Hi LS,
Thanks for the guidance, I will go over what I did earlier, I downloaded HUFFYUV from here, I followed the guidance from one of the links on the site ( created temp folder and copied to C drive SysWow64 and ran cmd command with copied code from guidance notes, looks like it didn’t work?
07-26-2024, 11:38 AM
Gary34 Gary34 is offline
The old page that you linked to has some versions of Huffy that aren’t ideal. If your using that link you want to use the version on top. That page was also made before Hoffmand’s installer. Now people recommend the 32 version and recommend Hoffmand’s installer. Hoffmand made it easier to install.
Adobe Media Encoder vs. Video Masterworks H264? RobustReviews Encode, Convert for streaming 1 09-26-2021 03:55 PM
Encoding HuffYUV AVI files to Blu-ray, media player? rokoko32 Encode, Convert for discs 9 02-12-2021 09:47 AM
Adobe Media Encoder CS3 not responding tgjasper Encode, Convert for discs 4 10-10-2012 03:20 PM
Help with Adobe Premiere and Huffyuv Files jrodefeld Edit Video, Audio 2 12-04-2011 01:50 PM
Adobe Media Encoder is giving larger than expected file size james_austin Encode, Convert for discs 5 11-03-2011 07:42 AM
