07-26-2024, 01:10 AM
Hi,
I’ve captured some AVI using Virtual Dub ( huffyuv + PCM)
Could anyone advise how I can use a different audio codec on capture with Virtual Dub so I can convert the file to mp4 (H264) using Hybrid ( is there a way to add a compatible codec?)
Thanks Tom
07-26-2024, 01:54 AM
Why? Hybrid converts PCM in WAV.
What file has issues?
07-26-2024, 02:31 AM
Hi LS,
When I put the AVI as described into Hybrid, it doesn’t accept the PCM format for mp4 h264( which I understand)
Is it something to do with the selecting the settings on Audio encoding in Hybrid, not sure if I’m missing something so obvious I can’t see it in the settings.
How do I get it too WAV?
Cheers
07-26-2024, 06:44 AM
- VirtualDub stream copy "save as" a tiny 3 second clip of the source AVI.
- Verify Hybrid still does not work.
- Attach to the forum.
badonica (07-26-2024)
07-26-2024, 08:27 AM
This is kind of Hybrid 101, but If you haven't already, on the Base page after you have loaded your source file, change the Audio dropdown to Custom. It has a big arrow pointing to it.
Then go to the Audio tab. I don't have the software in front of me as I type, but on that tab you need to pick the encoding you want for the audio (MP3, etc) and the bitrate on the left of the screen, then on the right click the + to add that conversion to the job list.
Once that's all set, Hybrid should be able to complete your encode.
The following users thank 7jlong for this useful post:
07-26-2024, 02:33 PM
Hi tried what you said but Hybrid crashed- these are my settings?
Cheers Tom
07-26-2024, 02:37 PM
I did select aac as the encoder and loaded it as the audio profile
07-26-2024, 02:39 PM
I need a sample clip.
07-26-2024, 02:54 PM
Hi LS,
I will send the clip tomorrow
Cheers Tom
Hi LS,
Please find attached files:
AVI
M2p - I had to change the file name from mp2 to mpg because it wouldnt upload? ( same thing happens in Hybrid - doesnt encode)
Thanks Tom
07-28-2024, 03:49 AM
I downloaded both files.
I opened Hybrid on my main Win7 encode/restore system, where I still use version 2020.09.18.0
I dragged the AVI to it, dropped. Selected my custom 4:2:2 H.264 profile. Set output file name, selected MP4. + to add, and moved to Jobs tab to start and monitor. No errors. Encode is fine. Attached.
Repeated on MPEG. Audio there, bad AR messed up. Checked in Hybrid, forced to 1:1 input. Ran it again Now encode in Hybrid is fine. Audio is terrible, helicopter noise.
You have a software problem, either the install itself is bad/corrupt, or how need to roll back some versions. Perhaps test my exact version, Hybrid_dev_2020.09.18-22611.exe, 403mb.
07-28-2024, 04:17 AM
Thanks LS
Will download your version of Hybrid and test.
Have I done the correct action on audio set up ( as per photo “+ audio encode” profile?)
What does AR mean?
Thanks Tom
07-28-2024, 06:10 AM
AR = aspect ratio
Are you just doing the default AAC settings? That's safest. I believe I am, but adjust the kbps to 160.
07-28-2024, 06:32 AM
Yes on the defaukAAC settings ( advice taken on board=160)
THE aspect ratio and audio noise has thrown me as I’m using Canopus hardware to capture to mpeg and never had an issue with their settings, given the time of the video AR 4:3?
Forcing it to 1:1 raises some alarms bells for me.
Ref Audio - There were definitely no helicopters around, is this a hardware system issue ?
I can’t hear it on my
mpeg ( but my hearings not great- it’s crap getting older, my car has a Bose sound system; so it’s wasted on me 🤣
Thanks Tom
| Thread |
Audio Capture Virtual Dub/ Hybrid
badonica |
Encode, Convert for streaming |
6 |
07-02-2024 11:16 AM |
Hybrid encoded H-264 mp4 files not playing audio?
andrewprjnn1 |
Encode, Convert for discs |
4 |
06-16-2024 06:07 PM |
VirtualDub causes odd deinterlace effect in Hybrid?
AstroLuna |
10 |
04-23-2024 01:32 PM |
VirtualDub capturing, interlace, editing, Hybrid?
SouthernerMan |
3 |
12-31-2023 04:53 AM |
Hybrid .mp4 files only playing audio?
andrewprjnn1 |
2 |
04-04-2021 05:26 PM |
