  #61
09-25-2017, 04:43 PM
koberulz koberulz is online now
Yeah, I pushed the master controls all the way to orange, and then pushed the mids a fair way as well (although closer to green). I used the frame of the ref that I posted earlier to discuss the ghosting/haloing, keying on his pants for the darks, his stomach for the mids and his shoulder for the brights.
Then on top of that some secondary corrections to desaturate the blues in the crowd and on the blue team's jerseys, which were overwhelming everything else in the picture, and push the wooden stands back towards red from the greenish yellow they'd become.
Unfortunately the colors vary so much that even if they're absolutely perfect for that ref shot (although now that you mention it the mids do look a bit red, although I have f.lux on at the moment), they're garbage elsewhere. VHP goes through about ten different skintones as they zoom in and out in that sample clip.
I'm outputting to three MP4 files: 576i25 anamorphic (I think that's the term?), 576p25 square pixel, and 720p50 square pixel. Using x264 through MeGUI to create .264 files, Audacity to create 224kbps AC3 files, and MeGUI's MP4 muxer to create the final MP4, complete with chapter markers. I also have a chapter file set up for HCEnc, so I can pull the 576i25 AVS into there and go to DVD.
The 576i25 version has Force SAR set to 12:11 in MeGUI's settings, which I thought was right, but if I play it back it looks wider than the 576p version. Have I flagged it incorrectly, screwed up the math for the square-pixel version, or is VLC just not reading the flag?
And how awesome are those colors? JFC.
09-25-2017, 05:20 PM
I wouldn't say that red, orange, and green are awesome for skin colors, but whatever floats your boat. I can't answer for what MeGUI, etc., do to video, I gave up on them a long time ago. I don't know which image is the square-pixel version or not. The top image aspect ratio is 1.37:1, not 4:3. Each image is from a different frame. PAL 4:3 standrard def has a pixel ratio of 12:11, yes, but recall that NTSC and PAL SMPTE 4:3 uses only 704 of the 720 pixels in the originals, and that has been modified by all the tape duping in various VCR's, and not all players fill the frame the same way -- so how to determine the exact ratios from the original camera recording would be anyone's guess.
Autocolor and autogain on the original cameras didn't do anybody any favors. Colors will naturally change after a long zoom because autocolor is looking at different color dominance factors when the camera angle changes.
09-25-2017, 11:31 PM
The top one is 576i, middle 576p, bottom 720p. Doesn't really matter which frame they're from, or what ratio was originally used, all three should match each other.
I think you missed the sarcasm.
09-26-2017, 03:37 AM
No, I caught it. Maybe I needed to add this guy to my own comment: .
09-26-2017, 05:16 AM
I'm guessing you're a basketball fan?
09-26-2017, 06:44 AM
Checking with MediaInfo the 576i file is 720x576 4:3, and the 576p file is 768x 576 4:3. Not sure what's going on there.
No idea where you got that impression.
09-26-2017, 07:13 AM
The top image of the three pics in post #67 is 787x576, which isn't 4:3, and you can't use odd-numbers for the width anyway. That one threw me off. 768x576 for square-pixel is correct for the middle image.
09-26-2017, 07:20 AM
VLC is obviously doing something to it, then. Not sure what.
09-27-2017, 05:04 PM
Shifted the mids away from red a bit and tweaked a couple of the secondary corrections.
Super black and white pixels / lines in lower field (only) of VHS capture ctrl-z Restore, Filter, Improve Quality 11 07-26-2015 03:23 PM
Please help to persuade VLC to fix field order metaleonid General Discussion 2 10-02-2013 05:33 PM
Wobbly/Out of phase VHS audio-Caused by tension error? Belmont Capture, Record, Transfer 3 04-25-2012 06:14 PM
Field Dominance / Field Order (Top or Bottom) deter Encode, Convert for discs 1 12-18-2011 10:35 PM
Remove extra lines (empty lines) from copied/pasted text with Notepad++ kpmedia Computers 1 10-07-2011 05:32 PM
