04-06-2023, 03:58 PM
tugatomsk9 tugatomsk9 is offline
I have been successfully capturing old tapes using the Panasonic EH50 (PAL) as the lineTBC passthrough.
However, I have a few poor signal recordings where I think lineTBC is doing more harm than good. I say this because when playing straight from the VCR the image is far more stable.
However, I was wondering if there are avisynth filters that can restore such issues, line frames "jumping around", image "wobbling" and such.
I have the link for the video sample:
https://wetransfer.com/downloads/89c...ource=sendgrid
04-06-2023, 05:32 PM
That's an awful large file for a mere preview. It doesn't need to be that big to show errors.
The ES10/15 type Panasonic DVDs recorders are not TBCs, and have quality-reducing side effects. I want about this all the time. TBCs should have good transparency, not actually make the image worse. The ES10/15 type recorders should only be used in situations that result in net gains. That's not going to be all tapes. There is a reason that actual TBCs are suggested, not the quasi sorta-kinda TBC(ish) items. When you go the quasi methods, this is what happens.
In general, no, Avisynth is not a cure-all to unring bells. Avisynth should only be used to correct what hardware cannot, not to fix bad or ineffective hardware. Good captures are always required.
I'd look at the sample, but I'm not a video system right now, just tablet on WiFi.
avisynth, linetbc, panasonic, poor signal
JVC HR-S9900U bad video signal? crissrudd4554 Video Hardware Repair 33 02-20-2023 02:39 PM
Video capture fails after a few minutes displays screen tearing redcar Capture, Record, Transfer 0 02-20-2022 09:21 PM
Line TBC cleans the image, frame TBC cleans the signal? Cortez Capture, Record, Transfer 8 02-18-2022 02:04 AM
All of a sudden, I get no video signal? jobeis Capture, Record, Transfer 2 01-09-2017 02:11 PM
Do I lose PQ advantage switching signal from s-video to RCA in signal path ? Mejnour Project Planning, Workflows 4 02-01-2012 05:12 AM
