11-25-2023, 01:12 PM
Townly Townly is offline
Hello!
Just finished all of my VHS tapes and now on to the Hi8. I have a DCR-TRV340 camera which is Digital8 with Video8/Hi8 playback and s-video according to this list.
I am planning on running s-video from the camera straight to my KONA LHI RO capturing through AJA control room.
1. Does this camera have TBC built in?
2. Any benefits to running the camera through my AG1980p or ES10 first?
Thanks!
11-26-2023, 02:29 PM
BW37 BW37 is offline
The DCR-TRV340 will have the typical Sony line TBC. All of the recommended D8 camcorders do even though the heading for their list does not specifically state it.
As I understand it, none of the digital processing benefits of the AG1980p can be applied in a pass thru mode so it won’t be useful for your Hi8 workflow. You can certainly try it to confirm this. The ES10 should be useful in pretty much the same way that you have used it for VHS, i.e. if the camcorder line TBC isn’t correcting tearing and squiggly verticals, the ES10 might do it better. Whether it will provide any “frame” TBC benefits seems to be the subject of controversy. If you have frame drops and audio synch problems, it will be worth trying since you have it.
Hope this helps.
BW
ag1980p, dcr-trv340, es10, hi8, tbc
Non-destructive post-capture workflow? (JVC HR-S6700, ES10) FinnTape79 Capture, Record, Transfer 4 06-27-2023 01:57 PM
Workflow using ES10? badonica Project Planning, Workflows 6 03-31-2023 12:04 PM
Will DMR-ES10 benefit my workflow? travvytrain Project Planning, Workflows 1 02-12-2023 07:59 AM
Workflow with DMR-ES10, JVC S-VHS, no TBC? Ninja99 Project Planning, Workflows 1 12-22-2021 09:36 AM
DVK-100 and ES10 workflow setup and configuration? tcirre93 Project Planning, Workflows 1 06-12-2020 10:06 PM
