04-29-2025, 08:21 AM
enygma's Avatar
enygma enygma is offline
Hello! I have inherited a working Microsoft Windows Vista era desktop from a family from my church and I'm curious as to whether or not it would work within a video capture workflow. It's an HP Pavilion "Special Edition" with an AMD Phenom X4 9550 @ 2.20 GHz (4 Processors, 4 Cores), 8 GB of RAM and four PCIe x1 slots. I have a license for Vista Home Premium Edition and I believe I have original XP installation media in my legacy binder.
So far as I can tell ATI seems to have only made capture cards for AGP slots. Are there any available for PCIe x1 slots?
Thank you for your help in advance!
05-01-2025, 02:47 PM
Yes, that's more than enough for capturing standard-definition video. If it's DV, it'll be a breeze -- that CPU won't even break a sweat. Same thing if the capture device has its own hardware-based compression (like MPEG2). If you're capturing uncompressed video, it should still be fine as long as the software you use isn't horribly inefficient and/or you're using an obscenely high bitrate.
capture card, vista home premium
Cannot install HuffYUV on Windows 64-bit Vista/7/10/11? [SOLVED] phyxius Encode, Convert for discs 41 06-20-2024 03:40 AM
ATI All in Wonder 2006 capture on Windows Vista? astrothug Capture, Record, Transfer 1 06-02-2015 10:03 AM
Ulead DVD Workshop 2 in Windows Vista and Win7 admin Author, Make Menus, Slideshows, Burn 28 11-18-2014 03:35 PM
ATI All In Wonder drivers for Windows Vista or Windows 7 ? Mejnour Restore, Filter, Improve Quality 12 02-01-2012 05:27 AM
Editing with Windows Vista 64? Steve(MS) Edit Video, Audio 2 06-26-2010 02:10 AM
